My only rolling stock purchase at this year’s ECLSTS was an F Scale AMS Tank-On-Flat car. It’s a nice model of a dubious prototype; I was told by several that no-one had a tank exactly like this one and that AMS had lettered it up for several Colorado roads. This doesn’t particularly bother me as I purchased a Data Only version with plans to letter it for the C.V.S.Ry. I was very excited to have a car I could use one of the new heralds on, so as soon as I was unpacked from the show I opened it up and installed a set of vinyl heralds. While I was putting on the heralds I had a chance to look the car over closely. Typical of an AMS car it has lots of detail; all of the brake rigging with brake hangers and shoes on the trucks. This is nice, but when I build a car I don’t bother with all the piping and rigging that no-one ever sees. The truss-rods are seen, and on this particular car, two of four were not in the queens posts. I tried to pop them in, but they won’t stay. This will take a drop of epoxy to fix. The finish and lettering is very nice,as are the top-side details. I looked closely at the tank bands and really think they were nicely done. As is common among several brands, the molded in wood grain is a bit exaggerated. The couplers are a BIG PROBLEM. They appear to be glued in place. The cast draft gear box is molded into the car and an unusual cover is screwed on from the bottom. This cover is so tight that it takes quite a bit of force to move the coupler side to side. I’m sure the car will not track through a curve while coupled. I tried to remove the cover to fix the problem. The screw comes out but the cover will not budge. It is either painted on or glued in place. Additionally, like other AMS cars, the lift bar and links will jam when the coupler swings. In order to run the car these two problems will need to be addressed. I’m afraid it may require surgery. For now it has been relegated to Shelf Queen duty…
I did try prying last night, but didn’t want to force it. When I tried lifting the “ear” it broke right off.
I did get the covers pried off. On one, the cast pivot pin cracked in the middle. I was able the clean that one up and put it back together, but the coupler head now droops unacceptably. The other pivot pin snapped clean off as soon as the lid broke free. Still looking for one of the springs (I have plenty of extras thanks to JB).
