It’s raining again today, so I decided to spend some time working on the Troublesome Tank.
It runs perfectly using the trucks/wheels from my AMS box car. These trucks do not have the little L bracket to allow equalization. The box car trucks do have a lot of drag - the car will sit still on a 3% grade! While trying to figure out the drag issue with them I found that by loosening the side-frame screw that they ran much more freely.
Thinking what is good for the goose might be good for the gander; I loosened up the side frame screws on the trucks for the tank. As soon as I did I noticed that the warp went away; when at rest all 4 wheels touch the rail. This was encouraging, so I put the original trucks back on the tank and did a few test runs through some switches. BTW - I used a little of the Loctite Blue thread locker on the side frame screws to hold them in place.
At first I thought the problem was completely solved. When being pulled, the car now tracks through the switches without derailing. Unfortunately this isn’t the case when being shoved - especially on facing point switches. Looking closely at the derailing truck/wheels I noticed a very large amount of slop inside the gauge. I can get a diagonally opposing pair of wheels almost 1/8" off the rail-head when rotating the truck. The back-to-back spacing on both sets of trucks had been previously set using G1MRA specs.
As an experiment I’m going to try setting the wheels a little further apart. News at 11.
