Some additional details… Basically, the bicycle speedometer consists of: - a unit containing the battery and the display. - a sensor that is typically mounted on the front wheel mount. A LONG wire connects this sensor to the computer. (I ended up cutting the wire as it was WAY too long.) - magnet that attaches to the spokes, and triggers the sensor each time the wheel rotates When you setup a bicycle computer, you have to “tell” it how big your wheel is. There’s a table of values for about 8 or 10 common wheel diameters - and you enter this into the computer. There’s also a mathematical formula you can use for other diameters. Well, in this case, I’m using 26" scale wheels from Sierra Valley, so I entered the value for 26" diameter wheels into the computer. I mounted the sensor between the wheels. I didn’t use the supplied magnet as it was too large. Russ had sent me some really tiny and really powerful magnets - about 1/4" diameter and I attached it to the back of the wheel.
So, every time the wheel rotates, it triggers the sensor. The computer thinks it is measuring a 26" wheel - so everything is already scaled. That magnet is REALLY strong. It kept picking up screws and washers off my workbench.
