Terry Burr said:
My K has been a pain in the ass since I got it. I’ve done the recommended upgrades (I think) but it still has issues.
The first problem are aristo wide switches, this I assume is a switch problem, I’m slowly fixing and soon replacing them. But the K hates them. And yes I realize they are at it’s minimum radius.
The biggest problem is the front truck it will not stay on the track to save it’s life. I’ve checked it’s gauge, I’ve added a stronger spring it still hops off at will.
Next is the first set of drive wheels. Any time the loco is under load it gets light in the front end and hops off sometimes in straights, sometimes in turns. Then it catches a switch and all hell breaks loose. It too is in gauge.
It’s not the trackwork, I’ve checked it, gauged it and checked level. Plus it doesn’t do it in the same place all the time. Also the connie has no issues with it at all as don’t any of my other locos.
Anyone know of fixes for either one?
For the record it’s battery powered with Rodney’s drive. It has the upgraded wheel weights and the 2 drive wheels are locked. Sorry, don’t remember which two at the moment.
Thanks for any help
Terry
You cannot lock 2 and 3, even though some clueless moron says that’s what you lock. It A) kills your radius, and B) causes lead truck derailment.
You will also spend considerable time searching for cylinder covers.
Lock 1 and 4, and confirm.
That said, I have one tight curve (the Tree) of oh, four foot radius, and it goes around it just fine.
If the gearbox is jamming in the slide, the rear of the engine is low. Nose is high.
Folks who designed this pig need to go back to school.
Pull the smokebox front off, load stick-on lead weights inside until you get the nose to quit bouncing.
If you can find much stiffer springs, add them to the rear two driver axle journals.
I have three K’s. This pig is used for demonstration. The Magnus is actually used. The other pig is in pieces, and has been for some time, with no plans to reassemble at this time. Someday…but why.
With weight in the nose, 1 and 4 locked, nose stays down better, and the distance between locked driver and lead truck is far less than with 2 and 3 locked, so the angle of the pilot flanges to the rail on a curve is MUCH less, and they don’t “pick” at the cylinder covers.
One more thing…put a little grease on the drawbar peg on the tender to keep the drawbar from hanging up…and…pick up the tender (loco still on track) and do a “swing” test, looking for jammed wires in those stupidly huge wire bundles.
You may have to loosen the plate that holds the wires to the loco chassis (remove boiler and cab, usually) to pull them out.
All sorts of things you have to watch out for.
BTW, my 35+ year old Magnus K-27 has…1 and 4 locked. Factory. That’s why I knew it worked. Sometimes experience helps, right?
TOC
