As for printing multiple parts simultaneously…,
I agree that nobody wants an errant piece to wipe out a bunch of pieces and also tend to print one thing at a time.
BUT…, consider that to do a couple minute print, the machine will spend 6 minutes going through its regular routines. You can reduce this time by telling it not to level the bed or calibrate the flow, and I will sometimes do this if I am trying to get a part to size without being overly concerned with the ultimate quality after I’ve been printing the same thing a couple times in a row.
OK, so consider the stairway I previously displayed. There are 24 steps and ironed solid, each step takes ~44 minutes. So the print time is 24 x 44 + 24 x 6 = 1,200 minutes = 20 hours just for the steps, if you do a step at a time.
So after I printed 4 or 5 individual steps, I modified the file to do 10 at a time. So the print time was reduced by 108 minutes or 1.8 hours. (The 44 minutes were also slightly reduced because the machine doesn’t have to vertically travel nearly as many times, and this also saves wear and tear as well as wear and tear from the leveling process, which does wear the plates from the bumping action.
AND just as importantly, those would typically be 108 minutes where you are overseeing the start of the print while it does its thing to be sure that the first layer starts properly.
So, ultimately, it comes down to the job. For example, if you were doing ties, you would want to do several at once.
