What I Look for in a 3D Printer
I’m hesitant to chime in amongst such an experienced crowd, but I too, am looking for a new printer even though my printer continues to meet my current needs. I am seeing a real advantage to purchasing an enclosed core XY printer. There is a lot of jostling for pole position right now, so I’ve decided to set certain requirements to meet my current wants and future needs.
While cost is a factor, I’m focusing on long-term value rather than just the upfront cost. A machine that’s reliable, upgradeable, and well-supported will always serve me better than a cheap one that quickly becomes outdated or requires constant fixing. Here’s what I look for:
1. Kit vs. Pre-Assembled: Why I Prefer Kits
I personally prefer kit-based printers over pre-assembled ones because:
I learn how it works. Assembling the printer gives me a deeper understanding of its mechanics, making future troubleshooting much easier.
I can customize it. Kits usually allow for more modifications, letting me fine-tune the machine to my needs.
They’re often cheaper. Since I’m handling the assembly, the cost is usually lower than a pre-built alternative.
I can easily service my machine. Because I assembled it, I don’t have to guess how to disassemble it.
That said, if I were recommending a printer to someone who just wants to print without the learning curve, I’d probably suggest a pre-assembled option. My kit took me 16 hours to build
2. Upgradability: A Printer Should Grow with Me
I don’t want a machine that becomes obsolete after a couple of years. A good printer will let me upgrade instead of forcing me to replace the whole thing. I’m looking for:
Swappable hotends and extruders so I can adapt to new materials and better print performance.
Multi-material expansion options in case I want to experiment with dual extrusion or color mixing.
Firmware updates that improve performance and add new features to the hardware I already own.
This saves money in the long run and reduces waste, which I consider a big plus.
3. Open Source vs. Closed Source: My Take
I strongly prefer open-source printers because they offer more freedom. If I want to modify the firmware, upgrade hardware, or print custom parts, I can. Plus, a strong community means I’m never short on ideas, printable upgrades, or troubleshooting help.
That said, I understand why some people choose closed-source printers. They’re often easier to use, more polished, and come with single manufacturer support. But I don’t like the idea of being locked into a proprietary ecosystem where parts, upgrades, and even software are controlled by the company. If they discontinue support, I’m out of luck. If they go out of business I’m really out of luck.
4. Reliability & Print Quality: It Has to Work
No matter how upgradeable or customizable a printer is, it needs to be reliable. I want a machine that:
- Works consistently without endless tweaking.
- Produces high-quality prints with minimal layer shifts or artifacts.
- Has features like automatic bed levelling and a solid frame to ensure accuracy.
- I appreciate a manufacturer who has tested multiple brands of filaments on their machine and have already tweaked the Slic3r settings for their machine.
I don’t mind dialing in settings now and then, but I don’t want to constantly fight with my printer just to get it working.
5. Software & Community: The Hidden Essentials
Good slicing software and a strong community are just as important as the hardware itself. I look for:
- A well-optimized slicer that gives me control over settings while staying user-friendly. I like a Slic3r that has beginner, advanced & expert settings. This gives me the confidence to tweak settings at my level of expertise.
- Regular firmware updates that improve performance and fix issues.
- An active user community where I can find help, share modifications, and learn from others.
- Good free after sales tech support (even with kits). I use my machine on the other side of the world which means I’m out of luck if a company only offers tech during their country’s business hours.
My Final Thoughts
For me, a 3D printer is a tool, not just a gadget. I want one that I can upgrade, repair (but rarely need to repair), and improve over time. I’d rather invest in a machine that grows with me than one that is only disposable or replaceable.
However, whether you choose open-source or closed-source, kit or pre-assembled, the most important thing is finding a printer that fits your needs and won’t hold you back. But… Invest in your machine.
In any case it’s exciting times in FDM printing for all of us again!
