Needed to start another thread for this part of the RR. Last fall I built the benchwork, and this spring/summer, in addition to the loop rebuilding, I’ve been working on the approach. I finally finished it today, except landscaping. I’ve built a planter on the end of the bench work, and used some of the trestle bents Ive had for several years to span the distance between the steel bridge and the planter. Cinder block core, and used bricks finish off the planter. It will get filled with dirt and plantings added.
