Aloha,
OK, we actually started, and, yes, John, “evolved” is the best word. I figured while we were at this project, we might as well learn what the parts of a real voyaging canoe are called. Lucky for you, you’ll get to learn them, too. I’ll be referring to the terms found here on a site about Hokulea.
To set the scale, the work gang of the Triple O agreed to a photograph as they rolled what I think may have been the handle of a garden implement onto the saw:
I cut it in half to form the ama (port) and akea (starboard) hulls. Oldest Daughter and Oldest Son helped me start to shape them both with our Dremel, which will probably be our primary tool from here on out. I had to guide Oldest Son’s hand, but Oldest Daugther was game to try her own hand at this:
I am wondering why we didn’t have a train on…
Anyway, I had begun to break down the saw, for, Lo! Kid-zilla had awakened! I have rule about power tools and Kid-zilla. If he is up, they are gone, so work had to come to an end. Kid-zill arrived and offered tools to the work crew to facilitate hollowing out the logs:
As I find PLAYMOBIL scale tools in PLAYMOBIL hands even more ineffective than 1:1 tools in my hands, I decided to test which of my Dremel bits would serve this purpose. Naturally, none in my possession would, so it was off to the hardware store and $8 are now out of my budget. Oldest Daughter and I began the process of hollowing out the hulls tonight. She will take over the fine finishing, to include removing the old varnish, with sandpaper. I will get the other hull hollowed out over the weekend.
The plan, such as it is, is to get the wa’a assembled, using dowels for the 'iako (connecting cross-beams) and single kia (mast). The shiskabob sticks will lay across the 'iako to make our pola (deck). At that point, we’ll stain it, and I’ll turn it over to the crew (human, not PLAYMOBIL) to fashion the la (sails) - probably from coconut fiber - and kaula (lines) - probably from twine. That should free me to transform a discarded Big Wheeler chassis, scrap craft lumber, and some wheel sets into the train part of this. I am thinking a 4-4-0 configuration…With luck, this division of labor should a.) get everyone involved, and b.) place the project on autopilot while I am indisposed.
I hope you are having as much fun as we are!
Aloha,
