I am a little behind on everyone but I had a good excuse…
So after getting the sand out of my toes, I sat down to draft my plan. I selected some very high quality drafting media as I needed the most exacting measurements and detail. It took me a while to find the perfect piece to embrace my genius…
I am going to build the “Bupp Gold Mine”. I will have a Head shaft with Hoist House at the top of the hill. Then two wood buildings stepping down the hill to act as the processing facilities. Then I am going to put an Ore Bin with bucket elevator at trackside. It will be located off this spur…
This picture is a little old but you get the idea.
So construction, hopefully starts tonight. I’ve been toying around with trying to do something different. I usually use a Coroplast core and then laminate plastic siding onto that. However, I’m tempted to use real wood on this one and build the structure that way. I want to use a Board and Batten design which makes it time consuming to build board by board…we shall see.
