I am in need of assistance with a new project I have acquired.
My problem is the original builder used very early Pacific drive units and in building the Challenger he removed the motor mount areas. I don’t know how he planned to power this thing but I could use some advise on how to complete it. My current options as I see them are as follows: 1) rebuild the old blocks ( I need the drive shafts, bushings and motors). This requires finding a place in these areas for motors and mounts. Here are pics of the modified drive units.
- Acquire new Pacific motor blocks and fit them. I forsee the same problem as above in that I will have to find a way to squeeze the motor and mount into those same saddle areas. 3) Convert an SD45 block to Pacific drive wheels. This would require removing the original SD45 mount tabs and fashioning new attachment points. However since the motors are internal to the blocks I won’t have to locate space for them in the saddle areas. I have compared the original blocks used, an SD45 block and a Mikado block. The spacing of the original Pacific units and the SD45 block are the same. I could possibly use an SD45 block turn the axles and drill for a cross pins and use the original Pacific wheels but think that might be more trouble than its worth. However depending on the availability or new Pacific drive wheels it may be the only option. I look forward to hearing from you. Andre’ PS I am also looking for a Vandy tender for this loco. I have three long tenders to either trade or sell. One is a UP, the other a Great Northern and the last a Lablaw (?) lettered. UP is complete, the GN is just the shell and frame and the other is complete but no sound system inside. I can swap parts among any of them to get what someone may want. Andre’
Seems like you are meeting each problem head on. It 's looking good.
