The work continues… As noted before I received a motor from Rocky for the Yellowstone. It came with a different hex coupling than the other two motors I have on the bench. This new one has a coupling with a longer round section on the motor end of the hex section. I needed to replace a motor in the Mikado block being used on the Yellowstone as it ran twice as fast as the motor in the Mallett. This new motor can not be used to replace either of the other two as it won’t allow the transmission assy. to slip into the brick. here’s the new motor coupling:
and the old:
the brass coupler has an open end so coupler can be pulled off with a puller. New style is blind , no access to the shaft. An email was zipped to Rocky looking for info on the loco this motor came out of. Rocky reported the motor with the black coupler is from a new Pacific. The other motor/coupler is from a Mallett. I called Aristo and was emphatically told that they had made no changes , that the motor/couplers were the same from the Mallet/Mikado/New Pacific. The evidence at hand tells a different story. Received several tidbits from folks at LSC, MLS and Aristo forums. Suggestions included trying heat, cutting back the hex section until the shaft was exposed and then use a gear puller and pushing the coupler farther on the shaft to get the needed clearance. Another option I toyed with in my head was removing it and turning down the offending added cylindrical length so the transmission seats properly. Doing so using the motor means death to the motor with all the swarf being sucked into the motor. I could tape it all closed and drive the shaft with my small lathe and turn it down without removing it. There is insufficient room on the shaft of the newest motor (black Coupler) to move it far enough to allow the transmission to slip into the brick when the motor and tranny are coupled. Tried heat on the brass coupler and it came off after a short application of a heavy duty soldering iron. The new coupler wouldn’t budge. Started to cut on the end of the coupler but I couldn’t find the durn gear puller so figured that would just be a waste of time! Wrapped the motor in tape all over and chucked the long end of the hex coupler in the Unimat threw a tailstock on the other and turned down the offending portion. Made sure I cut enough so it wasn’t putting pressure on the tranny as Leonard warned about. Thing fits in the block like it should now so will test it out in the morning as I am done in for this evening. Attached is a pic of the modified coupler.
Thanks for all the assistance guys! Helps to work thru things with more minds on the job! Andre’
