David Maynard said:
Of course you could go simple, a cable, pulley and counterweight. Not so much weight as to open themselves, but enough to lighten your load.
I agree David, pulleys are the simplest approach. I’ve got some to play with this weekend, we’ll see how it goes. Only downside with a counterweight is that you have to leave it connected, and the cables would reach across the bench top… not a big deal though, because this has to stay openable anyway, so it’s not like I can really use it like a work bench.
So far, the various approaches stack up in my head like this:
A. Leave it as-is (at least for now).
B. Rig pulleys for manual pull. Disconnect when not in use.
C. Rig for counterweights (and leave connected).
D. Make a loose 4’ long handle, which is inserted beneath the benchtop as a lever.
E. Use gas springs (long-term solution).
I haven’t listed a 12v hoist (from Harbor frieght), because if something wasn’t disconnected properly you’d see plastic flyin’ (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-laughing.gif)
