Dave Healy said:
Hans-Joerg Mueller said:
Ahhhh looks like I'm on the right track, now one can select standard or high quality. That's more like it! ;) :)
http://www.youtube.com/watch?v=VWAoTCRnyXQ
Man, don’t do that - had to sprint to the loo!
Seriously, congratulations on a huge effort! How much more of the five tonnes is left to shift?
The MOV suffix usually refers to QuickTime files. Our Panasonic Lumix saves natively in the same format. Unfortunately, there’s no substitute for pixels, and the resolution you’ll get from a MOV file isn’t comparable to what a camcorder can produce (e.g., MPGs of various descriptions).
You’ll find that the compression algorithms used by sites like You Tube and Vimeo will produce better results if you feed them something with more pixels than exist in a MOV file.
Dave, I hear you. To shoot the real stuff I’ll get out the good old Canon ES4000. Also did some sleuthing to find out what the Pros use
MP4 at the native 320x240 YouTube res and with the highest quality that will fit into the 10min or 100Meg limit. Reading all that “stuff” makes my eyes glaze over, but if it helps with the quality …
There is quite a bit left in the driveway that needs to be placed to build up the RoW embankments - you better believe there is good drainage with all that stuff. But I probably have to do another trip for more “hand rocks”.
