Yea! Got working class and marker lamps on PRR 4-6-0. Headlight and class lamps are track powered. Markers on pilot and tender are powered by battery for sound system in tender so if track power is lost in dark you’ll still know where your train is. And, lets you know if battery is in tender before putting loco away. Markers and Class Lamps use parts for Aristocraft Pacific with bulbs replaced by 3mm led from Battery Christmas lights. Lenses painted with Tamiya clear yellow and/or orange, and red. Stock headlight bulb replaced with 10mm Super Bright, 20deg cone, LED from Radio Shack: anxious to get over to Mike’s to see how many houses down the block that lights up!.
Mounts for lights are square Evergreen styrene tube through hole drilled and filed in deck. Yes, were painted so they don’t glow - first ya see if it works, then ya make it purty.
Huh, thought I made class lamps white for running Extra, why do they look yellow here?
El Gato is a railfan too.
