Charley,
In getting the boxes ready for packing I discovered that the set is only the plaster cast walls. No other plastic or wood parts are present. I remember now I was going to build a three stall roundhouse and ordered extra wall castings and floor with extra pit so I could do so. All parts for a three stall roundhouse are there, just no Grandt parts, wood or instructions. The side walls were broken in shipment but will glue together with almost no damage showing.
In view of this, I do not know if you still want the kit. I will be more than happy to refund your money if you wish. The extra parts would make into a really nice roundhouse should you want to keep it. It is a simple matter to cut the parts necessary to fit. If you decide to want a refund, I will probably build it up myself.
Tom
