I feel like I am way behind most everyone else this year. But I am making progress and confident it will get finished on time. Being as this is the first piece of rolling stock I’ve built, there has been a steep learning curve so I’ve spent a lot of time getting all the details figured out in my head and a lot of time modeling and printing most of them. Most of that is done now, so it will start to come together real quick. One set back is I decided mid-stream to change the way I was constructing the caboose structure itself. I think last week I had shown progress on a couple of the sub assemblies, well, that’s all out the window now. Instead of framing the structure in wood and then putting the siding on, I decided to print the walls and floor and add wood siding to that. Progress photos below.
We start with the addition of the final bolsters. These are attached using brass screws so I can replace them in the future if need be.
Next, I installed the queen posts, again with brass screws.
Here is an overall shot of the bottom so far. Next up will be brake detail and truss rods. You can see the CVG in the background sleep … I mean guarding the door.
Speaking of truss rods, that task has gotten started. I printed a bending jig to help me bend all the rods the same. This is the beta version, but it works pretty well. It could use a few tweaks but for now it will get the job done.
Its hard to tell, but there is a groove that the wire is in. Ok, now on to the caboose.
I’ve got the small door designed and ready to be printed along with the hardware for the side, sliding door. Hopefully tomorrow will see the doors installed and the trim work started. Thanks for following along.
