I feel like I got a lot done today, but I don’t have much to show for it. Brick has been grouted and weathered, siding has been cut and received its first coat of paint (maybe only coat, I kind of like the look).
So as I mentioned last night, I grouted the brick with a mixture of portland cement, hydrated lime and fire clay. Why did I use this mixture? Well, I have about 5 - 5 gallon buckets of the stuff. I simply mixed it a little wet and used my finger to smear it on and down into the mortar joints. This is what it looks like.
I then took a dry paper towel and wiped of most of the excess.
Depending on the look you’re after, you could stop here and let the mortar set. But I took a damp, barely damp, paper towel and wiped the brick one more time, lightly.
I know it looks shiney in the photo, but it doesn’t look that way to the naked eye. Next I took weathering powders and dirtied the brick up some to make it look a little older and then sealed all of it.
The siding you see in the last photo is cut from sintra board. To get the grooves, I simply used an exacto knife and straight edge. The siding is not attached yet, it is simply laying on top so I could see how it goes with the brick.
