Sorry its been a while but here is an update. I’m starting to working on the body modifications/additions. First I started with the plow. My E8 came with a passenger plow and as far as I know Aristo doesn’t sell their freight plows. However USA Trains does and I like the detail on the F3 plow anyways. I order the plow from Reindeer Pass, which then order the part from Aristo. They only list it as having the UP paint scheme, which is what I received.
(http://modeling.chris-y.com/images/103_034.jpg)
This is the standard Aristo passenger plow still mounted to the frame.
(http://modeling.chris-y.com/images/103_035.jpg)
USA Trains F3 UP as shipped with dummy coupler.
(http://modeling.chris-y.com/images/103_036.jpg)
Underside of aristo plow mount
(http://modeling.chris-y.com/images/103_037.jpg)
I needed to add some styrene to the USA plow so I could have a place to drill the the alignment pin holes. There is also a lip that I needed to shave off, which I started doing before I decided to glue on the piece.
(http://modeling.chris-y.com/images/103_038.jpg)
As you can see, the plows are pretty similar in shape
(http://modeling.chris-y.com/images/103_039.jpg)
Only difference is that the USA plow has straight sides by the steps instead of a continuous curve
(http://modeling.chris-y.com/images/103_040.jpg)
The only other modification I had to make to the plow was drilling the holes for the alignment pins and the screws. These are located on both sides of the mounting posts for the coupler.
(http://modeling.chris-y.com/images/103_041.jpg)
Here is the test fit and how it looks with the little bit of lip. I think it looks fine and wont be noticeable when its all painted.
(http://modeling.chris-y.com/images/103_042.jpg)
(http://modeling.chris-y.com/images/103_043.jpg)
In this next pic you can see the underside of the plow mounted. The mounting “holes” kinda turned into slots because the plow didn’t fit close enough to the rest of the body. This is fine though because the screws are what keep the plow in place.
(http://modeling.chris-y.com/images/103_044.jpg)
Now I added the stock Aristo front coupler. It fit through the USA plow and matches up very nicely. I just need to build some mounting posts for the spring lever so it stays centered.
(http://modeling.chris-y.com/images/103_045.jpg)
So I’ll be finishing up the coupler mounting whenever I get time, then I’ll move onto adding mu boxes to the plow.
