Well it took longer than planned but got the last part of the new workshop interior done this weekend.
That was the ceiling and lighting. I had to frame out, dry wall, tape & bed, then paint the HVAC duct area then add the drop ceiling and new LED lighting. Found a good buy at Cosco on these lights. They are rated equivalent to a 150 watt flood but only consume 23 watts each, the color is 3000K and used a total of 9 lights in the workshop. two are mounted in the HVAC part over the 15 foot long bench with the chop saw.
the
Pictures are untouched using available light only from the LED flood and no color correct, only exception is resized to better fit the forums format.
