As in another discussion, so as to not hijack the post.
The discussion was brought up about the type of glue to use for out door use. I have been using Tightbond III (TBIII) for a number of years in a number of uses out doors and have yet to have a failure. And I know that you’all have your personal preferences.
The discussion let to the point of is TB III water proof. Well I think the point is “Define waterproof” and what are the exceptable standards for you, and Non-waterproof defined glue.
Here is the ANSI testing requirements for “Type 1, and Type II” ratings. (this was copied from TB website)
What is the difference between the ANSI/HPVA Type I and Type II
water-resistance specification?
Both of these tests are conducted using 6” by 6” birch laminates glued
together to make three-ply plywood. The test for Type I is clearly more
stringent than Type II, and involves boiling the glue bonds and testing the
specimens while they are wet.
Type I testing involves cutting the 6" by 6" assemblies into 1" by 3"
specimens, boiling them for 4 hours, then baking the specimens in a 145°F
oven for 20 hours. They are boiled for an additional 4 hours, then
immediately cooled using running water. The specimens are sheared while
wet, and the bonds must pass certain strength and wood failure
requirements to pass the Type I specification.
Type II testing involves cutting the 6" by 6" assemblies into 2" by 5"
specimens, soaking them for 4 hours, then baking the specimens in a
120°F oven for 19 hours. This is repeated for a total of three cycles, and the
bonds must not delaminate to pass the Type II specification.
To pass the Type 1 test, says to me that it’s pretty darn good and will work for what I use it for. I’m not going to be boiling any of my structures for more then 4 hours!
.jpg)
