I’m trying to figure out the correct wiring diagram to use a double pole, double throw switch with a charging plug. I’m trying to do this with out a dpdt center off switch. I have a 9 volt battery, and a small motor that I’m trying to reverse/forward. The battery needs a charging jack as it will be sealed up. I’m not sure where to put the charging jack into this circuit.
I will also be adding a push button on/off switch. Granted it would be easier to have a dpdt center off switch, but I don’t have one handy.
Craig
