Howdy I’ve had a couple of concerns/complaints about the forums. Specifically that some images are getting cut off on the right. It seems to do with what resolution you have your monitor set to, and what font size you have set. But Id like to get a larger sample from the general public. So.
Can you see all the way to the end of that image? The very last thing should be a vertical red line where 800 should be. If you see less of it, please post the following: Monitor resolution (800x600, 1024x768, etc), and if you have fiddled with your browser font size. Thanks to TOC for this suggestion. Working toward a better site… Thanks
