As there appears to be no standard, is this template my best option for track laying?
Well, that depends! I donβt see any scale mentioned anywhere on that diagram. Iβll assume itβs based on LGB rolling stock that is generally 1:22ish. If that is the case, and you will be running LGB stock or smaller (1:24-1:32) you should be OK. If you plan to run 1:20.3 stock, you will need a bigger template.
What none of these templates take into account is car overhang on curves. Long cars on tight curves can have extreme overhang requiring lots more clearance on the inside of the curve than the template will show.
I just spent the last hour looking through my computer for a gauge drawing I have with no luck. If I come up with it Iβll post.
Yes, It is an LGB template with height stipulated for overhead wire. I have a flatcar and bobber caboose in 1:20.3 and thought if I ever get a locomotive it would be shorter than a pantograph.
Herself has ownership of the long orient express carriages, so curve clearance is an issue.
I have a wood 1:20.3 template I can photo and measure if you want. I never found the one I was looking for.
Jon, That would be most appreciated.
We found if a 2-year old can pass through the tunnel, you are pretty much good to goβ¦
This was Kid-zilla in 2018. The boy has moved from MOW duty to the locomotive works!
Thanks Jon. Iβm getting the ruler out. Looks like Iβll need more soil.
Ha! Sounds like a dangerous precedent Eric. With Kidzillaβs embracing the hobby, Iβd be hesitant to let him know you used him as a tunnel scale.
You just may find youβre moving up to 1:8 scale or even βGrand Scaleβ as he gets older.
As long as the shoes dont disturb the roadbedβ¦
Heβs in Hawaiβi, so they probably donβt wear shoes.
Bill, here is an NMRA page on clearance diagrams
Also look at RP-7.1 https://www.nmra.org/sites/default/files/standards/sandrp/pdf/rp-7.1_tangent_track_centers_and_clearance_diagrams_2019.01.pdf
