I recently ordered some cables and stuff from HobbyKing and noticed they sell an EZC-RC WiFi receiver. This replaces your regular r/c receiver in a loco and operates from your iPhone or Android phone.
As you can tell by the size of the pins, it’s about as big as a regular recvr. Only 4 channels, and no sign of the supplier’s website, so it isn’t clear what future this device has, but they are readily available from several sources. Range is supposed to be about 100m for a plane, 50m (150’) for a car.
The app for your phone is on iTunes but not on Google Play. However, you can download the Android app package using this link (do it on your phone)
http://www.himodel.com/en/info/soft/icPlane.apk.
My Samsung 5 did the download and then asked me if I wanted to install it. It then said my phone was set to not allow installs of apps that didn’t come from Google Play, but I was allowed to override that for one instance. It installed fine. Instruction sheet is at
http://www.himodel.com/en/rc_manuals_url.php?id=408
[Why this stuff is on someone else’s site is worrisome. . . ] There is also a car app with a typical pistol-grip picture but i didn’t think that would help.
Anyway, I plugged in a battery pack and a servo, and my phone found the WiFi network (ezc rc rcvr.) On the back of the rcvr is an 8 digit code key that you enter to connect, and it did. I then fired up the app:
This is how it looks - I was perplexed for a moment or two, then I realized the two circles with white dots are “sticks”. You slide them like ordinary TX sticks. (It can be flipped into mode2 if you want, and the servo movement can be reversed.) The right hand ‘throttle’ stays where you put it, but the other 3 channels (L/R on the rh stick, and all directions on the lh stick) are sprung back to the center. The phone vibrates gently to give you feedback that you moved a ‘stick’. It seemed to work fine and was operational within 10 minutes.
While it is a bit pricier than other receivers, (about $30) you don’t need a transmitter. I’m not sure if it will work for a steam engine if I can’t put it in forward or reverse and have it stay there - but my Spektrum stick TX had that for the first couple of years, until i took it apart and removed the springs. (No chance of doing that on my phone!) I wonder what the battery life will be if I have to keep my finger on the ‘stick’.
My next loco only needs the throttle control, so i will probably try it. Maybe the next generation will be a bit more configurable, and from a reliable source so we can ask for a train version of the app !
