Other data:
The stainless rail I speaking of is the 8’ long rail sections threaded through the Aristo ties. In this particular location where the narrowing exists, the ties permit lateral movement of the rail. The problem sections are about 6" long. To prevent the problem where I suspected it most probable – long curves for example – and prior to threading the ties on those long rail pieces, I cut away the spacers on the plastic ties and thus created a curve with the ties virtually resting against each other to prevent the problem of lateral rail movement thus changing the guage.
Thanks for the input – I’ll report later on how well the spacer idea works plus another suggestion:
Our contributor in Washington state, “Dr. G”, also offers installation of small spacers inside the holding tang on the rail plates to push the rail back held with glue. I’ll give this a try also. If you miss “Dr. G’s” input, a good reason is he is in the middle of a Jaguar restoration-- not one you stuff.
FURTHER THOUGHT:
Comparative to Aristo’s ties strips I think the LGB product is stronger. This is a conclusion reached only because I have had no history with the LGB sections of track “going out of guage.” HOWEVER, those sections are prefabricated track sections not rail threaded through ties. That may be the difference.
Yes, I did use a railbender on the stainless. My limited experience with the stainless rail – granting all the advanatages of not having to clean – is it has a MEMORY! Bend a long section of curve that is at 8 foot or less diameter, and the rail prefers to straighten out. True, this ever so slightly, but it is different than brass lengths not showing the same desire to straighten. Having helped others install 8 foot lengths of threaded brass rail bent to 6-8’ diameter curves was the comparison.
Wendell
