When having power pickups in rolling stock, you have two options:
- Roller bearings (your wallet will hate you)
- Friction
Usually with non bearing wheels, you have two “carbon brushes” pushed against the wheels with springs. The carbon brushes means you can have a non-moving point of power pickup against the revolving wheels. Which means friction is necessary.
But the thing is, there’s ALREADY a non-moving part of rolling stock which the coaches are connected to and the wheels are in contact with: the axle boxes!
If we made the axle shafts out of metal, it should provide reliable electric conductivity, right? Sure, contact might not be perfect in some areas of bumpy track, but most rolling stock have 8 wheels anyway. Good lubrication shouldn’t inhibit conductivity, either.
What’s your opinion on my idea? Would it be a good idea to wire rolling stock to metal axle boxes? Would it negatively affect preformance in any way?
Thank you for reading.
