Jon Radder said:
Craig, Maybe I am over simplifying, but doesn't it boil down to this...
Once you call and get permission  for a reverse move, the front of the train changes to the direction of travel.  To go back the other way you need to call for permission again, and when you get it, the front of the train changes to the new direction of travel.
Our local short-line (and my railroad) does not operate by such complicated rules. Once they get permission in a block they can do whatever they want within it. No other trains are allowed into the block until they clear. And seeing as there is only a couple of trains operated per day over about 100 miles of track they rarely come close to each other.
Over simplified, but complicated. The reverse movement on happens in a controlled block that has independently controlled crossovers. 99% of crossovers don’t have this ability. What this does is it allows a dispatcher to pre-line the crossovers, while another train is still in the block. These blocks are huge, 1000’ at least. Anyway, each crossover is individually controlled, and at each, there is a bond for the signal system. So when you move past the bond, it lights up on the dispatchers screen as you having left that section of the block (think of it as multiple blocks within a single block. I know it’s complicated). If you move back into that ‘block’ that you cleared, it in effect becomes like running a red block, because after you cleared the dispatcher theoretically could have already lined someone else up. And this has happened in real life, hence the creation of the reverse movement rule.  I’ll have to draw up a picture to explain…
Here’s the rule out of the GCOR. 6.4.2A is what I’m talking about.
"6.4 Reverse Movements
Make Reverse movements on nay main track, controlled siding, or on any track where a block system is in effect at restricted speed and only within the limits a train has authority to occupy the track.
6.4.1 Permission For Reverse Movements
Obtain permission from the train dispatcher or control operator before making a reverse movement, unless the movement is within the same signaled block.
When a train or engine is advised that working limits have been established behind their train, obtain permission from the employee in charge to make any reverse movements, including within the same signaled block.
6.4.2 Movements Within Control Points of Interlockings
A. Control Points or Manual Interlockings
Except when in track and time, if movement stops while the trailing end is between the outer opposing absolute signals of a control point or manual interlocking, the movement must not change direction without permission from the control operator.
B. Automatic Interlockings
At an automatic interlocking, the movement may change direction within the limits of the interlocking if it continuously occupies at least one car length of the limits.
What was funny was when I went back to Kansas City for engineer school the instructors told us specifically. You don’t need to learn this rule, as it only applies to the Chicago area. All of us Seattle guys spoke up and said nope it doesn’t. They couldn’t even explain the rule to us, we had to explain why and how them…
Clear as mud? Boy I sure got this thread off topic fast.
Craig
