I have a problem with one of my locos. It’s a Bachmann 4-6-0, with BBT drive, Phoenix sound, Aristocraft Revolution r/c, and battery power. It was running, and then just stopped (inside a tunnel, naturally). I figured the battery was dead, so I charged it and put it away. But since then, it still doesn’t run. The sound works, and the transmitter successfully links to the receiver, so it’s not the battery.
I’ve opened the tender and looked for loose connections or burnt fuses but everything seems to be ok. I suspect the problem is in the engine. Now, I opened the engine myself when I converted it to battery power, but I’m not really keen to do it again. So I was hoping to find someone locally (San Diego area) who could handle it. Sadly the one guy here who did that kind of work is in hospice.
So I’ll probably try to do it myself. However, unless the problem is something obvious like a broken wire, it’s likely to be beyond my very limited skills to diagnose and repair. If that’s the case, and I can’t find anyone locally, I’ll be forced to ship it somewhere for repair. Any recommendations? Who does this kind of stuff?
