Get out the chain saw!
When the outdoor division was first built it was decided to bridge over the roots of a very large Maple tree. Here’s a photo from long ago…
At the time - more than 10 years ago, there was plenty of room between the bridge deck and the root…
As the railroad grew so did the root to the point that it made contact with the bridge deck and began pushing it upward. This spring I decided that something needed to be done. The bridge was temporarily removed and a triangular slice of the root was removed to get the deck back where it belongs. I forgot to get pictures before the bridge was put back…
The cut in the root brought the deck down at least an inch and leaves an inch or so of clearance under the deck. I’ll probably need the remove a little more as the 10 year old plywood deck bridge it beginning to rot. I’ll replace it with a deck girder bridge made from 2" aluminum tube and PVC.
“Natural Bridge” has also grown infringing on the clearance below. An early photo…
And here’s the same root late last winter…
This one won’t require major surgery, just a little chunk taken off the lower right. Most of my stock still fits through, but caboose smoke stacks get bumped. The biggest problem will be the pitch dripping from the wound once it’s cut.
