Hi all, Can someone tell me what this is and what it is used for??? Thanks Rick
An old time track powered Back’n’Forth speed controller.
Thanks Tony,
So is that a “reversing unit” with a settable time
for the stops?
Thanks
Rick
Yes.
Just simple ON - OFF control. Speed is set by the actual trackside control used to power the reverser. Uses Diodes to limit travel.
Oh darn and I thought it was the drive controler for a TIME Machine.
David Kapp said:You need a sonic screwdriver.
Oh darn and I thought it was the drive controler for a TIME Machine. :)
i would suspect, that it might be a timer for trains to stop for a certain time at stations.
