I’m almost ready to start work on a new building, similar to my abandoned stone cabin. I plan to use the same technique – creating a foamcore form to cast the walls. When I did the abandoned cabin, I used rectangular blocks of styrofoam to make the openings for doors and windows in the cast walls. The openings were not very precise, but since that was supposed to be a crude, older structure, it was acceptable.
This time I want the openings to be much more accurate. I want the sides to be parallel and perfectly level, and sized correctly to fit the door and window castings.
But I’m stumped as to what kind of material to use as “blocks” in the form. It needs to be at least 1/2" thick, but no more than 3/4" thick. It needs to be able to cut cleanly, hold its shape, and yet must be either flexible or fragile enough to allow me to get it out of the cast wall without damaging the wall.
A large part of the problem is that I have no decent tools. I can think of lots of materials that could be cut to shape with a bandsaw or tablesaw, but I need something that can be cut with an x-acto knife.
Any suggestions?
But I hate repetitive tasks, and I think this idea will be worth it in the long run.
