What are these plugs called?
What are these plugs (male and female) called and where can I purchase them?
thanks
They’re DC power plugs. There’s a bunch of sizes of them (outer diameter, and inner pin size). You’d be best measuring your size. They’re available on Amazon, among other places.
https://www.amazon.com/10Pack-Adapter-Connector-Dustproof-Lsgoodcare/dp/B078YP4CP6?th=1
The most common are used for LED strips 5.5MM x 2.1mm. I buy them from Aliexpress in packs of 6 or 10.
10Pcs DC Connectors 5.5x2.1mm
You can get them with wire connectors.
5pairs Female And Male DC Connectors 2.1x5.5mm Power Plug
You can also get chargers for your lithium batteries with them already fitted:
1PC Battery Charger 16.8V DC 2A
If you don’t like Aliexpress, the same stuff is on eBay and other sites.
Thanks guys for the response. I found them on Amazon.
