Since I was told that some dinosaurs would cut and throw, we are now entering Jurassic Park.
This is the locomotive wiring and circuit boards. Board 5 is stripped, still on the floor of the firebox. The two diodes are flipped off the board, and the new chuff connects to those points, to allow a feed direct to the former Ames Super Socket… All components and wiring to the optics are removed.
This is a sheet of black .080" styrene glued to the top of the tender opening. This prevents any water OR rain from condensation under the coal pile from affecting electronics, and allows future installation of loose coal by the customer.
This is the underside view of the plastic sheeting installed, plus the 4.5AH battery pack.
This is the tender floor with the speaker installed and the entire Ames Super Socket assembly removed.
This is the new .080 deck I built. I cut the old Ames Mounts short by enough to just clear the magnet of the speaker. I could mount the gear up under the new coal opening styrene, but thought I’d try this. The 6 amp RCS unit is installed, the Sierra and interfaces. Receiver is under the back of the new mount board.
This is another shot. Note just behind the coal “spill” pile on the deck you can see one of two 1/4" holes now in the deck. These are just below the spillway behind the coal retaining board to allow any water that comes past the coal to actually get out of the tender without running down the cableways to the tender to loco sockets. I intend to be charged and wired today in the tender. The reason I used a 6 amp unit is that I have actually tested one of these with shiny wheels on my old aluminum track, and it draws 3 amps when it grabs.
No optical chuff, no Ames Super Socket and NO PROBLEMS!!
