Bruce Chandler said:
So these are stuck on to each car?
I’ve never operated with waybills, but I’ve certainly read a lot about them, so I think I understand the routing part. I’ve never been clear on how you determine which car goes with which train, or how many cars I should pick up for a train.
Bruce
We generally operate with two person crews. The engineer runs the trains and the conductor/brakeman handles the waybills and plans the run.
Our older ones were 5x7, the new ones (see above ) are smaller at about 5x5. The photo on the waybill helps the conductor spot the car easily.
We have two types of trains on our railroad. The locals/wayfreights handle all the switching on a particular route. These trains start at one of the yards. The conductor makes up the train based on which cars in the yard have a destination served by the train. Blocking of cars helps later switching operations. Any car at an industry on the route that has a waybill indicating it is to go somewhere else is picked up (to the tonnage rating of the locomotive) and cars marked for that industry left.
Our through trains generally go from one yard to another with only one or two drops/pickups on route. If the tonnage of the train exceeds a single locomotive the engineer can call for a helper.
Form 19s are used to govern train movement and we generally have a dispatcher.
If you can make it in June you could operate on both The SJR&P and Bob’s layout which use two different styles of operation.
Steve
It is not absolutely necessary that all cars have different numbers but it sure helps. For the few cars we have left with duplicate numbers we try to keep them at different areas on the layout. (These last few cars will be renumbered this spring)
