As many of you know, a couple years ago, I started making couplers in brass. The process was to design it in Sketchup, have one (a pattern) made by Shapeways in brass, and send that to a foundry. There, a rubber mold was made, which was used to generate wax copies for the investment casting process.
Recently, I started clandestinely researching wax casting on my own. I figured with the experience I had in RTV mold making & resin casting, I should be able to make the jump to wax casting.
I experimented by melting jewelry wax in a crock pot, and injecting it with a syringe. It almost worked, but I couldn’t get consistent results. The more I experimented, the more I saw that heat & pressure had to be finely controlled. That led me to buying a wax injection machine:
I decided to try it out on a coupler/draft gear pattern that was more prototypical, so I designed these parts & had them printed in FUD (Frosted Ultra Detail):
I found the wax injection process to be a new learning curve. Unlike resin, wax has to be injected under pressure. The tin-cure RTV (MoldMax series) I normally use, was too soft. Platinum-cure RTV offered a wider range of durometer ratings, and after some experimentation, I settled on Smooth-sil 950.
Learning to cut the molds was also a new experience to me. In wax casting, all molds are glove molds. That means the pattern is mounted on a sprue, and completely enveloped in RTV. After the RTV sets, the pattern is carefully cut out, making a two part mold (sometimes more than two parts). I quickly realized this was an art. I watched video after video on YouTube on cutting rubber jewelry molds, and butchered a couple of my own, before I got the hang of it.
Anyway, here are the wax patterns I was able to make:
These will go off to the foundry next week, and I’ll find out in a couple weeks if he can cast them or not.
In case you’re wondering why I’m doing this, this puts the burden of inventory control on me. Slight revisions are easier for me to keep up with than the foundry. There is also an up-front cost to having them make the rubber molds (starts at $50 for the smallest molds), so I’m hoping this will let me lower my end costs.
