For the MIK I plan to make a concrete/mortar base for the building. I am going to use the Ray Dunakin/Jim Rowson method of making a form adding rocks then back filling with concrete/mortar. The goal to be a solid concrete base with a stone facade both top and sides.
My question is this. How can the concrete base be protected, waterproofed, so it can remain outside without rotting? It will be on my bench work so drainage will be good and it really should remain relatively dry. It won’t be sitting in a puddle; but it will have dirt under and around it that will get wet and hold water like a sponge at least for awhile. I am going to likely bring the building in over winter but would like to leave the pad out if possible.
I considered using the same tar they use for sealing foundations. But I also don’t want to reinvent the wheel if people already have a good answer.
