Warning, Xmas Train at CVS is not G gauge
Heads up fellow cheapsters, if you see this set at your local CVS store and are tempted to add it to your G roster or just for your holiday set up:
Be warned, they may look G, but the are actually WIDER, at almost 50mm gauge. They cannot be re-gauged, as the wheels are not on axles but independently mounted.
I have seen these trucks before on Xmas sets at Big Lots before, and was able to modify the trucks for G but it takes some work.
So be aware if you see these.
