Found out the hard way to never use ordinary clear polymer sealant on styrene plastic. I always use a ‘neutral cure’ clear gutter sealant, but due unable to source, I went for the ordinary cure sealant. I am aware that it may cause rusting on steel but was horrified yesterday afternoon to find that it eats styrene plastic. My articulated mother hubbard is no more. I sealed two Bachmann Annie cast weights inside the body over the rear drive, nearly two weeks ago. This afternoon, I noticed a deformity in the body shell. The plastic was completely softened and in parts dissolved. A complete write off. Two weeks of work and several hundred dollars down the drain!!! One quarter of the boiler moulding was totally deformed and dissolved as if attacked by a solvent. The sealant used was a clear polymer ‘paintable’ type. Normal silicone cannot be painted after application. No warning on container apparent as regards use on plastic, although the writing is so small that a magnifying glass is needed to read the fine print.
I carried out a similar sealing/adhesive application about two years ago on my 4-4-4-0 Mallet with no effect on the plastic. The sealant used then was the neutral cure type clear silicone adhesive.
All I could salvage were the two drives, the cab and some detail bits. The rest is in the garbage bin.
Sorry, I just couldn’t resist.
