Dan Stuettgen said:
Pete: I have several 4-6-0’s that I bought for just that purpose and have been working on a cad drawing from origianl Baldwin 2-8-0 blueprints of the frame to have on lazer cut from ABS plastic. How did you make your frame out of brass, did you have it machined , or did you solder it up piece by piece? I have a resistance soldering rig I could use to solder up a frame, if I could find the right size brass material.
Dan S.
Dan,
I was interested in making a frame the way they do in the smaller scales - two flat pieces of brass soldered together and then drilled, cut, etc. I think it is 1/16th x 1" strip. The target loco was a Baldwin 2-8-0 used by the D&RG and the EBT around 1890.
This actually ran, with the crude rods, but I now have some s/s rod ends that can be bolted together to make jointed rods.
The front axle is pivoted so the whole thing is equalised. The two center axles can move upwards if necessary so the flanged wheels stay on the track.
