Steve,
The turntable bridge is only 16 inches long, just barely room for the short loco’s and trail car.
A little track work progress to show. The first switch to go into the yard area after coming down off the switchback from the lift out bridge. I decided to use Aristo short switches in the yard area to conserve space and take advantage of their sharp radius. Although the code 332 to code 250 conversions became a bit of work. As you can see the switch is mounted to a sheet of Acrylic that is spiked to the ground with a couple of 16d nails. This picture was taken before I painted the Acrylic sheet flat brown the same as the rails and ties.
This shows a little more progress with the track to the turntable installed and ballasted. The main line continues on to the Mill area and the switch to the abandoned mine spur.
This shows a closeup of the switch at the mill trestle (not built yet) and the spur up to the abandoned mine. In this picture you get a good view of my “bright idea” to adapt the code 332 to the 250. I used an Aristo joiner then cut a short piece of code 332 aluminum rail to slide into the joiner. The base of the 332 aluminum was cut off so the code 250 would slid up to it in the rail clamp. It seems to hold very well, we will know the truth after a “season in the sun” as they say. The Redwood retaining wall is where the trestle behind the mill will start.
This view shows the track work to date. The spur to the left going uphill to the abandoned mine and the spur to the car shop in the middle distance. The unattached switch in the center will go to feed runaround trackage and the spur to the shaft house in the background.
After installing this little bit of track on my hands and knees i remember very clearly why I made the decision to raise my railroad up on table tops. I have always claimed it was to defeat the burrowing mammals but it was really to save my poor old aching joints.
Thanks for taking a look.
Rick
