Version 2 of what I may want to achieve hopefully with pictures this time and examples to make myself more clear. I’ve been continually reading and researching and have re-thought some of my original ideas.
Scale will still be 1:29 because USA Trains makes a GP38-2 CP Rail engine and that is what I want to see. I do not see any other manufacturer offering this in any other scale.
I am not going with a particular era or setting to model. So freelance. That said, I won’t be mixing and matching just anything. This doesn’t change. It means the electric steam engine I want must be close enough to 1:29 so that it looks properly sized to the GP-38. I am also picky on what the steam engine looks like. This seemed to cause the most confusion last time trying to balance look/scale/radius. Hopefully example photo makes it clear no regarding styles I like.
Radius available. I should be able to do a minimum radius of 5 feet for any loop the GP-38 will be on, but have not had any great ideas yet on how to fit something into the yard that I would be comfortable with and happy with. I will make an additional post with my random thoughts on what can be done in the yard. To loop the steam where I want to see it I have a radius of just 2.5 feet barring a brainstorm in design. This also seemed to be an area of confusion as any electric steam I found that can handle that radius does not have the look I’m after or is too far out of scale to 1:29 to be acceptable.
I don’t know if a Kadee coupler switch in is required anymore. I may be fine with what USA trains makes since it appear every engine and car I would want they make…
I am considering now using the AirWire drop in system for battery powering the diesel engines now over Revolution because it would greatly cut down on costs and give me further leeway on a track plans without concern on reversing loops, Wyes, etc. The AirWire has the plug for a Phoenix P8 board which is what I was looking at for the Rev system as well. I am still on the fence with the whole control system and probably because lack of knowledge on if everything can be converted easily. I’d have to hire out the mods either way.
I am now considering brass rail over the TrainLI Nickel Brass track especially if I use battery power. I may have over-estimated how much cleaning was needed after visiting a layout here where the guy ran a Scotchbrite pad over the track a couple times a year and that was it. He was using track power and had no problems with just one power feed and 150 feet of track. Brass also seems to offer the most options on switches and suppliers. I suspect flex track would still be a requirement over sectional.
I still want at least two trains to be able to run at once in both hands-on and automatic for when I just want to sit and watch.
I still hope to have at least on over/under area of track, but if you can see my pictures you know this is a challenge. I haven’t done the elevations yet, but there won’t be a lot of natural terrain change for risers.
I want to fit the layout in the existing look of the yard to compliment the yard not make the yard fit a railway. I am not opposed to relocating/removing some plants, but trees and concrete won’t be removed. I did remove shrubs that were along the fence which will give more options. Those shrubs were going to be removed anyway it just may be a fortunate timing for a railroad as the replacement plants will now be delayed until a decision is made on a train vs. planting something new only to move it later.
I do struggle with the hobby aspect, like any hobby I have had. It’s probably the biggest roadblock to just getting started. I know guys here have said it is never finished and that is the hobby. I have to try and wrap my head around it vs. having a project that needs to have a start and finish. I am still not keen on this being yet another solo venture as it appears that would be the case here.
So if anyone can look at this drawing and see something special please comment.
Thanks.
Bart
Photo 1 & 2 could be areas where I could remove some grass to allow for 10’ diameters.
Photo 3 shows grass that I would prefer not to remove so one can move from pavers to grass area easily with mower, etc…
photo 4 shows the area I was hoping for the steam engine run. It is in a main viewing area, but 5’ diameters is all I can fit.
I’ll save additional comments for another post.
