Jake Smith said:
I bet you could use the textured spray paint for the texture and if you cant get the right color, then paint over it with the right color.
Thanks Jake…I think it’s probably better to paint first if you use textured spray. The reason I say that is what Kevin mentions about the solvents eating away at the foam.
I’m noticing that the foam has a tiny tiny cellular-type structure, which probably accounts for its strength and light weight, being mostly air, and when I sprayed a test block of foam with spray paint, the paint seems to make it’s way into those cells, little “holes’” and make them bigger and more noticeable. Not really a good thing unless that’s the effect you’re after.
On the other hand, those tiny cells, as well as the rough side of the masonite, would probably take the applications both Kevins are taking about. Then I’m thinking base coat of the camoflauge paint over the application once it dries thoroughly. The camoflauge paint is so nicely dead flat, matte, and then maybe some texture paint. Then color from there.
My little problem at the moment is that I made the arches on the bridge too narrow and pointy instead of broad and stable. Now I got to re-do them; not a big deal but I lost a couple of hours work. Dang. I’ll never make that mistake again…who would have thought there was so much math and engineering in a simple arch? I’m loking forward to getting the engineering over with and a base coat down…then I’ll finally be in my element, painting!
