Back in 2019 we had a thread about using composite ties outdoors with some having sucess while for others it did not work.
During our November Ops session one of the points came unsoldered on the first turnout I built using composite wood for ties more then 20 years ago and I had a chance to bring the turnout back indoors and do a little maintenance. I now use a much stronger solder so I reworked both points.
I have made a lot of improvements over the years in turnout construction so looking over a 20+ year old turnout to see how it held up was fun.
There are two different types of composite wood, capped and uncappped. The capped wood has a plastic shield around the composite wood and if you cut the plastic you expose the underlying composite wood to moisture which it is not designed for.
I use MoistureShield Vantage uncapped composite wood which has a 50 year sliding warranty and they advertise you can cut it without impacing its structural integretity.
I have found that when you cut the wood two thin the wood has a tendency to break when stepped on so i have gone to close to 1/2 inch thickness to avoid this issue. This turnout had 1/4" ties and one was broken where the spikes were and was replaced.
None of the spikes had come loose from the ties and while there was more texture on the old ties than new ties the overall integritudy of the turnout was excelent. ( if you loook closely at the photo you can identify the new tie which is the first tie past the point of the frog) The wood I use is gray so I recoated the ties with a black stain (which in time will wear off), and reinstalled the turnout. I now look forward to another 20 years of use before its due for another time in the shop.
Stan
