Gary,
Consist is a great way to run multiple unit lashups (normally). If you have less than 6 engines or so this makes plenty of sense.
If you have over 10 diesels in your roster, there is no need to have an RX in every engine unless you want to control them all individually. If so, you have to buy an RX and battery for each engine and then maintain the batteries indepently. F units are the most logical engines to run off a single RX…who needs independent control of an FB unit?
The single RX GP lashup is nice too. I can run my GP solo, or I can add a second or third unit via corded connection.
This has all the financial advantage of running a high-capacity battery car, with the operation advantages of having your battery onboard the loco.
