I’m converting an SD-45 over to onboard battery power with QSI decoder/sound board and G-Wire.
I plan to use two (2) Crest 21 volt LITHIUM-ION batteries with the Crest Y cable to run the batteries in parallel to obtain higher amp hours.
SHOULD I HAVE DIODES IN THE Y CONNECTOR TO PREVENT BACK FLOW OF ELECTRICITY IF ONE OF THE BATTERIES SHOULD GO BAD? The batteries will always be removed for charging and will not be charged in the locomotive.
I also wanted to put in a slide switch that would allow me to select to receive power from the onboard batteries or pull power from the trainline cable to a battery car towed by the locomotive. SHOULD I PUT IN A SLIDE SWITCH TO SELECT THE POWER SOURCE OR SHOULD I WIRE THE TRAINLINE CIRCUIT IN PARALLEL WITH THE ONBOARD BATTERIES AND NOT HAVE A SWITCH?
SHOULD I PUT A FUSE BETWEEN THE BATTERY AND LOCOMOTIVE ELECTRONICS?
Thanks,
Russ
