I was just scratch building a Rail Bus , and needed Treadplate .Looked in my goodies boxes and found I had only one sheet left , insufficient to do the job .
Having had a similar problem before , and being an unbearable smartass , I took a sheet of aluminium kitchen
foil and using a folded soft cloth ,pressed the foil hard over the Treadplate , and lo ! One free sheet of treadplate .
Like I said , done it before , so knew that you have to handle with care to prevent damage . To stick in place , I use photomount spray ( dodgy , just touch the foil to it and you have a wrinkle )or the proprietary stuff for sticking windscreens in or the never dry stuff for squirty grass .
By the bye , you can use foil in the same manner to produce one-off moulds of anything you fancy . like a section of brickwork . the flatter the object , the more successful the technique .
On an allied subject , could we have a modelling tips forum ?
Mike M
PS A thought just occurred to me , I did mean use new foil , not greasy turkey covered torn stuff . Heheheheh .
