I have a well used track powered USAT S4 and it is not as smooth as my other USAT engines. When it takes a trip around the RR it starts to sputter with poor electrical pickup. I checked it yesterday on my bench and all wheels and shoes are picking up current. When I run the NW2 and the S4 at the same time with seperate trains it seems the S4 wheels get dirty really fast. Comparing the wheel sets on both engines they are both worn but the NW2 will run many smooth laps without a hiccup. The wheels on my GP38 are nice and shiny. Could it be that the plating has worn off the S4 and that is what is causing the problems? If so the NW2 can’t be far behind.
Is there anything that can be done short of buying new wheels which are $20 per set and do you think worn wheels is the problem?
Thanks.
