I bought a used (but never run) Hudson in SP livery a while back, and finally dug into it this week. I’m installing AirWire, and integrating the stock sound (Phoenix 2K2) and TAS smoke setup.
I started by totally gutting it. I unsoldered all of the wires from everything and yanked all the incandescent bulbs, wiring, and stock circuit boards.
The conversion will consist of a 18 V, 10 Ah Li-ion pack in the tender, connected to the locomotive through the stock cable. I’m doubling up conductors in that cable, as they are 24 or 26 ga (a little small). Four of the 6 will carry battery voltage/ground, and the other two will be control lines for the backup light and markers (though I can’t imagine an operational scenario where markers would be needed). Below is the connector in the locomotive with the doubled power connections.
I rewired the two switch panels to provide separate power to the G3, sound board, and smoke unit. The second pole on the sound switch (yellow wires) will interrupt the DCC signal from the G3, as that’s its primary source of power. The “lights” switch is wired for battery voltage, but not currently used. Here is the sound/switch package, ready to go. The blue wire is for chuff and will get attached to the sensor when it’s in place.
The G3 will mount on a custom bracket, just forward of the stuff in the photo above. The bracket uses two of the screws for the speaker enclosure cover, and one of the posts from the stock circuit boards.
I’m held up at the moment waiting for a speaker to arrive (FRS7, naturally). One other detail I finished is the LED conversion for the firebox. I used 3 mm orange LEDs. These will get the “flicker” effect from the G3.
That’s all for now!
