USA trains J1e Hudson
Has anyone done any work on this loco?
I have one that the lights and sound work but
Not the motor. Not sure how the loco top comes
Off. I tried USA Trains but got no response.
David
Hello David.
I cannot help you with why the motor doesn’t work but this battery R/C cnversion thread tells you how to remove the top. http://www.largescalecentral.com/forums/topic/14181
The relevant text is after the 4th pic.
Thanks,
Getting the unit open gets me to where I need to be.
I am hoping it is something simple like a bad switch.
David
Maybe Nick S. will comment, he has several.
Strange that the motor does not (apparently) work at all.
I just opened the unit.
Seems the owner or someone must have played with it.
The 3 screws holding the boiler on were loose.
I screw inside was missing.
I found a wire broken at the motor.
Also a broken wire at the smoke unit motor and
One of the front light wires.
Repaired all three and life is good.
Thanks for your help guys
David
