Everyone - After further investigation of the factory wiring situation in the loco, I decided to forget trying to use the basically non-existant DCC-Ready feature to install a DCC decoder with the existing wiring. Instead, as also recommended by everyone, I stripped all the electronics and wiring out leaving only the two track power wires coming from the loco’s motor block.
I appreciate Dan Pierce’s recommendation to install a DCC Power/Sound Decoder instead of using the existing Phoenix sound unit. But I like the quality of the Phoenix Sound units so I’m either going to reuse the existing Phoenix board (will test it out on my Phoenix PC Interface software) or install a new Phoenix PB8 or PB17 board. There are plenty of on/off switches provided in the loco to wire a power on/off switch for the Phoenix board that will be available when I need to program CVs on the DC/DCC power decoder. I know Dan and others swear by other DCC brands, which is fine, but I’m primarily a Massoth DCC components user and I have a Massoth dealer in Germany for my inventory. So, I’ll be installing a Massoth XL power decoder. I’ve also replaced the existing speaker with a brand new Massoth/Visaton FRS 7 8 Ohm 8 Watt 200 - 20,000 Hz speaker that can be seen in the below photo of my stripped loco. Shouldn’t take me long to install the Massoth XL decoder, rewire the Phoenix sound unit operating from track power, wire the headlight, taillight on the tender, and the smoke unit.
Does anyone know the voltage capacity of the smoke unit…I assume I should provide it full 22 volts dc current from the XL decoder?
Thanks!
Tom
